charliealphabravo
I am looking at options for the repair of a shear crack in a cast-in-place pedestrian bridge (early 70s). The condition was discovered during renovations and runs the full width of the bridge although the crack widths at the opposite end are acceptable.
The bridge is about 30 feet wide and spans about the same distance. I only have an architectural plan at this point so I haven't confirmed the longitudinal reinforcement, but seeing as it is basically a 12" thick flat plate I don't expect to find much effective shear reinforcement. The railings are integral cast-in-place, but as you can see they were discontinued near the support.
Thanks in advance.
Thanks in advance.
