Pedestrian bridge collapse over six-lane highway - I295 Northeast DC 6
Spartan5
Minor injuries reported.
Wonder if it was struck by truck.
URL]
Well the uncrashed version doesn't look in the best of shapes before hand, but that truck is very suspicious. A simple blow would be enough to slide it along the carriageway by the look of it.
It looks as if the exhaust stack is untouched.
I'll bet on a high load in the next lane that continued on out of the picture.
It looks as if he was carrying a load of sacks or bags on pallets. They don't often pile those loads nearly as high as the top of the stack. On the other hand never underestimate the ingenuity of a truck driver when it comes to overloading a truck to avoid an extra trip.
Bill
Ohm's law
Not just a good idea;
It's the LAW!
The first image in LittleInch's post shows what appears to be pre accident.
The shots following are from google maps and show a capture date of 2019. This is not the worst underside of a bridge I have seen.are somewhat deep. The number of scrapes (zoom in on googlemaps to see this) indicate the bridge is a bit low with respect to the standard interstate clearance.
Some witness video [link ]Storyful = Passerby Captures Aftermath of Collapsed Pedestrian Bridge in Northeast Washington[/url]
Construction of this roadway was 1957 to 1964. I think this part was closer to 1964 and the pedestrian bridge was most likely part of the original construction, so it is perhaps in service for 60 years.
Some History - Anacostia Freeway (I-295)
I wounder about how the torsion loads from the signs play in here. How much of the design margin do they use up?
Some of the gouges on the underside of this bridge
Wow- from the way the hood flew off I wonder if the driver broke the seat belts- that looks like a very high-G stop.
It's ironic that a perfectly good bridge was instantly reduced to a pile of concrete and scrap metal by a truck with "FRANK'S SCRAP METAL"
painted on the door.
Bill
Ohm's law
It's the LAW!
Judging by the flattened front rim, I guessing the truck pulled a wheelie when the load caught before being slammed violently back down into the ground.
URL]
I know it's difficult to pick out, but could the sign have slipped down leaving poles sticking down into the carriageway??
Ugh, I hate driving under those ped bridges in DC... they always look like they'll collapse with just a person walking across it. I prefer to park outside and take the metro in(so I can be in a derailment like everyone else).
DC infrastructure is... sketchy, in areas.
Dan - Owner
The sign damage was collateral damage.
The truck cab and the high exhaust stack cleared the bridge with no damage to the stack.
The dump box was elevated higher than the exhaust stack and higher than the bottom of the bridge.
Bill
Ohm's law
It's the LAW!
I'm confused by the term subframe in this context. If sub means under, can it really be raised so high? Or was it the bed of a dump truck that was raised?
My vehicles complain with warnings and chimes whenever a door or seatbelt is left unlatched. It would seem this condition should likewise be alerted.
he truck was probably fitted ash a Roll on / Roll-off waste hauler. In this context the waste box sits on a set of rails which are used by the truck to slid the box to the ground and later to slide the box back onto the truck.
Here is a video of the operation of a roll on / roll off truck bed
