JAYDEE23
Materials
- Jun 16, 2009
- 146
I am trying to creat a simple excel spreadsheet for my office to use to calculate hydrotest for PED work. We fabricate venturi tubes (so piping).
Per Annex 1 7.4 hydro is no less than
-1.43 x MAP (easy enough)
-1.25 x MAP and MAT
So the consideration of MAT means multiply the ratio for stress between test and design temp right?
Well what figures do we use??
Code of construction allowable stresses (ASME B31.1 in this case)i would think not since PED specifies how to derive allowable stresses.
PED allowable stresses (if so there are many possible ratio's dependent on the method that results in the lower stress value...per Annex 1 7.1
Im lost..some help is appreciated...
-1.25 x MAP and MAT
