behindpropellers
New member
- Feb 23, 2005
- 73
Well after installing 2008 we have been dead in the water now for about 24 hours and counting.
I got a 1720 error, and this is what the var said to do:
"the error message is due to IIS
1. Go to Add and Remove Programs and uninstall the Web Portal and go to the IIS Services and delete the pdmweb folder if the uninstall did not delete it.
2. Modify the PDMWorks server install and make sure that there is no red X in front of the Web Portal and now reinstall.
3. If you are still getting this Error 1720 make sure you don not have IIS Lockdown running. If you do you need to turn it off and install the Web Portal again."
Well I did not have any of that installed so I called the VAR again. This is the next set of directions:
"Per our conversation you are going to back up your vault; un-install the PDMWorks Server and re-install PDMWorks Server 2008.
As I mentioned, this was will be resolved in SP1.0, but this is the work around SW tech support is providing."
So I backed up the vaultdata folder and re-installed. After it was re-installed I overwrote the new vault data with the original files.
At this point I have lost all of my settings, and our projects are not showing up in the vault. I know there is something in the folder since it is about 2GB.
Right now the VAR is working directly with solidworks on getting this resolved.
Anybody else have this problem?
