PDM/Works VAULT ERROR 102 2
BandH
Automotive
Jul 17, 2000
78
Hi all,
We've recently installed PDM/Works 2006 and I am responsbible for getting it up and running. In trying to check-in a drawing and related part, I get the following error:
VAULT ERROR 102:
You have no permissions to change document properties
Failed on check in of (drawing name)
Check In aborted
I have "Allow change document properties" turned on the global settings
Thanks in advance
Make sure you own it and you are checking in the correct revision.
Chris
Systems Analyst
SolidWorks/PDMWorks 05
AutoCAD 05
ctopher's home site (updated 06-21-05)
FAQ559-1100
FAQ559-716
Run the Vault Admin utility (or check with someone who has access to it) and make sure your account has write access to the applicable project.
I am having this same problem. We are just now getting our PDMworks vault going, and one of my users cannot check-in. They also keep getting the ERROR 102.
I am the PDMworks Admin. I know that they do have the proper rights to the project. Plus they are doing a new check-in, so having ownership at this point is not possible. The user is picking the correct project to check-in to.
PLEASE Help....
One thing that I have discovered is that only the users that have been created in PDMworks 2006 get this error. This is not good...
Hi there,
I am in a similar situation to Jakek - I am also the PDM Admin and this is a new check-in.
We are using the following service packs:
CLient Version: PDMWorks 2006 SP2.0 Build 0052
Vault Version: PDMWorks 2006 SP2.0 Build 0052
Thanks again
Here's an update. When I log on as PDMWadmin (this is the default administrator name) it allows me to check in drawings, parts etc - does this give you any other ideas?
I am also waiting for a response from my SolidWorks reseller so if I hear anything I will let you know.
Solved the problem myself!
I logged in as VaultAdmin and checked under the Lifecycle Tab. Under the "Control access to document revisions at the selected status as follows" seciton, you have to provide RW access to users. You may not want to give access to all lifecycle stages, I've limited Configuration Control to Administrators.
I feel like a fool. I forgot to put my new group on the lifecyle.
Thanx.
BandH and Jakek,
Thanks for the valuable info. A star for you both.
