PDM Solutions
  • Thread starter Thread starter Roxel
  • Start date Start date
R
Roxel
Guest
Hello
Firstly sorry if any of this is confusing or unclear - im new to the data management side of things, Pro/ENGINEER operation is more my thing so bear with me!
My company is currently running an ancient version of Pro/PDM to manage drawings, models and documentation etc (not quite sure of the release but it would be late 1990's era). We currently have 11 Pro/ENGINEER 2000i (yes 2000i!) seats/licences. As Pro/PDM is no longer supported these days we have a potential problem should the system fail in any shape or form. At the same time we would like to upgrade to Wildfire 3.0 but as you probably realise Pro/PDM does not support the latest Pro/ENGINEER files and to complicate it further we would like to move away from the Silicon Graphics 'unix' platform to todays favourite Windows XP. We have thousands of historic drawings/models/assemblies spread over multiple Silicon Graphics machines which would need to be tranfered from Pro/PDM to the chosen solution. Our Pro/ENGINEEER and Pro/PDM software is heavily customised (being in the defence industry) and is likely to add to the complication.
Also our company now requires a PDM solution that will integrate both AutoCAD and Pro/ENGINEER files, which doesnt seem to be too much of a problem looking at some of the solutions on the market. The two suggestions so far have been Windchill and Agile, however i have no experience of either. Pro/INTRALINK has been looked at but conversion of Pro/PDM files does not seem feasible.
Does anybody have any recommendations or ideas of a way forward in terms of selecting a PDM solution that will meet the above criteria (conversion to windows platform, retaining historic ProPDM files, integrating AutoCAD and ProENGINEER drawing control and allowing for the introduction of Wildfire 3.0)?
Pro/PDM does manages files upto Wildfire II but YES WF III is a bit of problem for PDM. As you have said that you would like that the data mgmt tool would manage both Pro/E files as well as Auto CAD files..yes I guess Agile is a better bet because f its ability to handle both these files plus AGILE is easy to suctomise and as you have mentione d that at present you have lot of customisation done to PDM / Pro/e.
Agile & WF III work well on XP and are pretty much stable but Pro/e does gives some trouble if you open very big assemblies but that has been the case throughout.
Windchill-based solutionswill mange both file types. Depending on workflow requirements if you want Intralink or PDMlink.
We are in the process of finishing a migration from Pro/PDM to PDMLink with WF2.
I-cubed has migration tools avialble to help with the files moving from Pro/PDm to a Windchill-based solution.
The Special Report link is showing a very limited set of PDM/PLM tolls available for the Pro/E market.
For PTC products they reference Intralink 3.4 and PDMLink 8. Why not Intralink 8?
There are no UGS products listed. They do have products, TeamCenter Engineering, that can manage Pro/E data.
Which ones would you add (other than TCE from UGS) to make this
listing not very limited?
Maybe Intralink 8.0 isn't explicitly mentioned since it's a subset of
PDMLink 8.0 (e.g., the PDM functionality in PDMLink is Intralink 8.0).
Use Pro/Convert to convert Pro/PDM to Pro/Intralink 3.x.
Then use Pro/I 3.x to PDMLink or Intralink 8.0 data migrator to migrate the data to PDML or Pro/I 8.0
All solutions are from PTC -- the most reliable source of migrating Pro/Engineer data. And they are probably free if you are maintenance paying.
