David Browne
- Nov 29, 2017
- 12
[Please refer to attachment throughout]
Dear fellow users,
I'm validating a reactor vessel design as per the client's requested design code [PD5500]. Essentially I have three parts to this simple assembly - backing plate, shell and front plate - bolted together and sealed around the peripheral of the machined recesses (see O-Ring). Given the self-energising nature of rubber O-Rings (Du-Pont's Viton product in particular), the design establishes the sealing potential is independent of bolt torqueing - i.e. regardless how much the bolts are torqued, only the contact force between the backing plate contact face and shell face increases, ultimately unchanging the O-Ring sealing capacity.
Taking this information forward, and, applying PD5500 Section 3.5.5 for calculating minimum thickness for a bolted flat end, would it be conservative and correct to assume the required calculated bolt load for gasket compression is irrelevant given the position of the O-ring, and deformable nature of an O-ring? Would it be fair to assume there is very little bolt loading required for actual O-ring sealing and to purely satisfy the requirement of assembly?
I don't have a conventional spiral wound gasket or RTJ whereby a calculated radial distance (hg) from the PCD to the reaction force mean diameter, G, is required for joint sealing.
THE ISSUE
The calculation is giving me thickness to be unrealistic = approx. 41mm minT.
DesP: 5.65MPa
DesT: 50degC
Shell O/D: 324mm
Shell I/D: 298mm
Shell nominal thk: 13mm
Calculated shell mint: 7.32mm
PCD: 362mm
Couldnyone offer their own experience of approach when considering O-ring sealing potential and requirement for bolt loading is pertinent to leak prevention.
DB.
Dear fellow users,
THE ISSUE
DesP: 5.65MPa
DesT: 50degC
Shell O/D: 324mm
Shell I/D: 298mm
PCD: 362mm
DB.
