H
HO-229
Guest
Good Morning all,<?:namespace prefix = o ns = "urn:schemas-microsoft-com
ffice
ffice" />
Please forgive me is this sounds elementary, trying to wrap my mind around the sequence of events that must happen to add a plotter.
I have a HP1055CM (postscript 3 supported) plotter that I just added to my network.
Background/Things I believe to be true:
1) Set the load point for the new plotter/printer (loadpoint\text\plot_config)
2) Create a new pcf
When I visit the PCF file location I do not see text files that have the below format type and I am curious why I do not see something like the below example pulled from the WWW that I can tweak to fill my needs?
Trying to understand the basics of configuring this plotter and the correct roadmap to adding the plot device.
I believe I did a fairly comprehensive research but I am always nervous about adding/changing something without a clear understanding
Thanks in advance
Example:
plotter LASERJET4
button_name LASER-NAME
button_help LaserJet Location....
plot_drawing_format YES default
plot_segmented NO default
plot_roll_media YES default
plot_label NO default
plot_handshake software default
create_separate_files NO default
plot_with_panzoom NO default
rotate_plotting NO default
allow_file_naming YES
plot_name NO
interface_quality 3 default
plot_destination printer default
plotter_command windows_print_manager \\servername\printername
pen_table_file table.pnt
plot_sheets current default
paper_size A4 default
paper_outline NO default
plot_clip NO default
plot_area NO default
2) Create a new pcf
Thanks in advance
Example:
plotter LASERJET4
plot_name NO
