Patterns using curves - need advice
  • Thread starter Thread starter rude
  • Start date Start date
R
rude
Guest
I am trying to create a pattern using a curve. I am tryingto create a cut on an inside wall of a non-circular surface. I have created a curve along this surface and now want to create an equally spaced cut along this surface. Everytime I work thru the pattern after creating the first cut the pattern seems to stary away from the surfeace. I place the first cut at the start point of the curve.
Thanks in advance
rude
I'm assuming this isnt a flat surface or you wouldnt be having this problem. Is this a projection curve? Try grouping the curve and the cut together when you pattern it.
Edited by: CPiotrowski
The curve is in a single plane and I have referenced the curve withthe cut. I was able to successfully pattern a point on the curve, then when I tried a reference pattern of the point to the cut, I recevied a failure notice saying 1) incompatible dimensions, 2) overlapping geometries. Could there be a problem with the curve?
ok.. select ur curve.
place 2 datum points on ur curve in the same feature. i use "real" values vs "ratio" just depends which way u like to work it.
make a VSS on ur curve. Drag the start and end points to the 1st and second points.
group the points. + VSS
pattern the points over a value.
make sure that your points dont overlap or 1 go behind the other as you pattern as this will produce errors. If in doubt pattern the points b4 doing the VSS to make sure you have done this correctly.
Best to take it a step further.
if u take a Analysis feature and some equations u can really make this very kool and adaptive.
<DIV>
</DIV>
<DIV></DIV>
<DIV>Dear Bro,</DIV>
<DIV>I did what you said but i could not reach the "Pattern" (see attched file).
</DIV>
<DIV>Please guide me how to pattern datum point if you're free (Could you share the file?
)</DIV>
<DIV>Thanks in advanced.</DIV>
<DIV>Best Regards</DIV>
<DIV>2007-07-12_035156_pattern.prt.rar</DIV>
<DIV></DIV>
I actually solved this by just re-creating my curve internally rather than having an external curve.
Thanks for the advices and tips.
rue dog!
Hi Friends,
<DIV>When Ipatterned datum pointfollow datum curve.Some points ran out of curve (see picture)I'm so confuse...Someone can help me,plz!!!</DIV>
<DIV>Thanks a ton</DIV>
<DIV>View attachment 3872</DIV>
That is the same exact problem I had. I stoped it simply by creatingthe curve internally in the pattern creation rather than selecting a curve. A bit inconvienet but it worked for me.
<DIV>It did not work for me
</DIV>
<DIV>Any advice, Bro? Thanks </DIV>
are u sure u referenced ur points to the curve?
upload ur file, easier to see what went wrong
<DIV>Hi Bro,</DIV>
<DIV>Thanks for your response
,</DIV>
<DIV>This is my achievement
, but the pointsstill ran out.</DIV>
<DIV>Any advice would be much appreciated.
</DIV>
<DIV>Thank You</DIV>
<DIV>Have a Good Day</DIV>
<DIV>2007-07-15_211215_pattern.prt.rar</DIV>
sorry mate i can only open wf2 files. ur in wf3
might be a bug in wf3 ? maybe ur on a beta versions or something
patterning a point on a curve, any curve really is quiet simple.
make a curve
put a date point on the curve
select the point hit pattern
<DIV>Thanks for quick response</DIV>
<DIV>This is step of pattern 2007-07-15_220842_Pattern_curve.rar(power point file)</DIV>
<DIV>Maybe there are some steps were wrong. Plz giude me bro.</DIV>
<DIV>Thanks in advanced</DIV>
<DIV>
make a curve
</DIV>
<DIV></DIV>
<DIV>Yeah, I think you're right. There's bug in wf3.</DIV>
<DIV>Thanks a lot</DIV>
<DIV>Regards</DIV>
I dont think there is a bug in WF3. Your procedure is wrong.
You are right to the extent of creating the curve.
While making datum points, make TWO points instead of ONE.
Say you need a total of 50 points, Your first point will be at a ratio = 0 and the next would be at a ratio = 1/50 = 0.02.
Dimension pattern the points with an increment of 1/25 =.04. (25 = 50/2)
Trust this helps.
BY THE WAY I AM STILL ON WF2.
HOWEVER YOU CAN TRY THE ABOVE METHOD, OR WITH A SINGLE POINT WITH DIMENSION PATTERN.
ENSURE THAT WHILE SELECTING THE CURVE, THE WHOLE CURVE IS SELECTED for creating the DATUM POINT.
From the power point file it appears that only a part is selected.
Why would we have to place two points? I understand the reason behind it, but why is this not explained (oh wait...PTC). nevermind. Hopefully they will come through with a fix for this such that we don't have to make two points instead of one.
Possibly, could we create it from a certain distance away from a reference?
<DIV>Hi SRINIVASANIYER1,</DIV>
<DIV>I've got it, we have to make datum point at RATIO 0.0 with one or two point (up to you). Thank You, Bro.
</DIV>
<DIV>To rude :make datum point with RATIO 0.0 first, after that pattern that point on curve, those points wont run out of curve.
</DIV>
<DIV>Best Regard to All</DIV>
<DIV></DIV>
<DIV> Dear Bros,</DIV>
<DIV>I've got the pattern command, but i have a question.</DIV>
<DIV>I like to pattern as puppet's picture (the cutting bended alongwith curve)</DIV>
<DIV>But I could not do it. Please see the pictures.</DIV>
<DIV>Any advice would be much appreciated.</DIV>
<DIV>View attachment 3925</DIV>
<DIV>View attachment 3926</DIV>
<DIV>View attachment 3927</DIV>
