S
SRINIVASANIYER1
Guest
I wish to pattern numbers on a PCD. The component is typically a Flange with holes on a certain PCD. The intent is to show either "Protruded" or "Cut" numbers beside the holes so as to identify them. I know that I can "Dimension Pattern" the numbers, "Unpattern" them and then edit them one by one.
Is there a method to automate the process through parameters and relations? A more intelligent way of doing it?
