mncad
Industrial
- Dec 27, 2002
- 256
I have a cylinder that has shallow slots cut in the OD parallel to the centerline. I now need to pattern the slots around the centerline of the cylinder. I cannot use circular pattern because I need the angle between each slot to vary. There are 10 slots so I need 36 deg between 1st and 2nd, then 37 between 3 and 4, then 35.5 between 5 and 6 and so on. I tried a sketch driven pattern, but that doesn't seem to work. Any ideas?
Thanks,
mncad
Thanks,
mncad
