Hello. This is my first time on this site. I am hoping to utilize the experience on here. I have a scenario that I have tried to calculate, but I am not sure of my results. Here is what I have.
I have a material with the weight of .305 lbs/ in^2. Size is 25um. For calculation purposes, consider this the diameter of a sphere. The ultimate tensile strength is 144 ksi. This material will be at a velocity of 750 m/s hitting a surface with a tensile strength of 13,500 psi. The material hitting the surface will completely be deformed as needed. The surface it is hitting can not be considered to have a spring factor due to multiple particles at that velocity hitting it. There for my assumption will be no time to spring back. The force I calculate seems to be a bit higher than I would think it should be.
Thank you for your time.
