KootK
- Oct 16, 2001
- 18,611
Hi all,
I want to design some partial depth stiffeners for a steel beam with some concentrated loads on it. Normally I'd just go with full depth stiffeners but I'm trying especially hard to be fabricator friendly this time around.
AISC J10.8, "Flanges and Webs with Concentrated Forces" ,states that FULL DEPTH stiffeners should be designed as little mini-columns with certain stipulated geometric limitations. Fine.
But how should one design a partial stiffener? Should it be treated as an even shorter mini-column? Can you ignore the buckling limit state and just design for b/t and shear transfer?
Also, does the last sentence of AISC J10.5 preclude the use of partial height stiffeners for addressing the limit state of web compression buckling? I can't tell for certain from the language and punctuation used.
Thanks!
Thanks!
