randy64
Aerospace
- Jul 31, 2003
- 170
I searched around a bit and found some conflicting opinions on this.
What I'm referring to is a cylindrical feature that is, let's say, about 30 degrees of an arc.
Can or should this be used as a datum feature?
I've seen the following: "It's an example of a "partial feature of size" which is a classic pain in the CMM world. The partial arc (in this case it's around 1/4 of a circle) has no opposed points anywhere, and is technically not a feature of size. Finding its actual "axis" is highly uncertain if the feature has any form error."
Also seen talk of 4.5.10.1 from -1994 (which is what we use here), Mathemetically Defined Surface showing that it's okay to use a partial cylinder as a datum feature.
What I seem to be seeing is that it is legal, but in reality it is a bad practice that may give bad results. Would you say this is a correct assessment of the situation?
What say you?
What say you?
