Part Name -> File Name
roseda
Automotive
Oct 4, 2001
90
When I create a new Part and save it, V5 automatically tries to save it with the same name as the Part i.e. "Part.23"
If I then change the Part name to something else and SaveAs, V5 still tries to save with the original name - is there anyway to make it take the same filename as the Part name? My part names are quite long so this would be very handy.
The thing you have to do first is before you save your part, right click on the tree, properties, and on the product tab, you give it a part number/name. When you save it, it will take the same filename as you put in the part number.
Yes, that works the first time.
I would like to change the name in the tree a second time e.g. to create a new version and ideally, when I use SaveAs, v5 would save with this new name - but it doesn't - it still uses the previous name.
If you wanted to do a new version of the existing copy. You could open it with New From... and then rename in the tree. Then, when you do a save as, it should take the new name from the tree.
Good Luck.
You can also do a COPY/PASTE SPECIAL, and BREAK LINK. That will let you re-name the part and save it as a new document.
