L
LS65
Guest
I am using WF4, here is my issue. I have a part that is used in 50+ assemblies. I would like to add a datum to the part drawing for use with GD&T. I insert a model datum on a surface and then use this as a datum ref in my GD&Ts. In the layer tree this datum is hidden so it does not show on the part (it still shows on the drawing though). When I open a drawing for one of the parent assemblies, the newly created datum shows up on that drawing. I do not want this to happen! Is there some way to prevent this from happening by changing something within the part? I do not want to have to open all 50 assemblies to hide the datum!
Thanks for your time,
LS65
LS65
