Part Body - Define as in work object 1
Alan Lowbands
Aerospace
GB
Hi Gents,
I'm trying to get all the selected parts in an assembly to have the main body set as the 'in work object'.
Could anyone tell me where i'm going wrong please ?
thanks
Alan
Language="VBSCRIPT"
Sub CATMain()
Set oSel = CATIA.ActiveDocument.Selection
oSel.Search "CATPrtSearch.BodyFeature,all"
intNbSelected = oSel.Count2
If intNbSelected > 0 Then
For intIndex = 1 to intNbSelected
Dim oPart
Set oPart = oSel
Set documents1 = oPart
Set partDocument1 = documents1
Set part1 = partDocument1
Set bodies1 = part1.Bodies
Set body1 = bodies1.Item("PartBody")
part1.InWorkObject = body1
Next
End If
oSel.Clear
End Sub
Hi Alan,
ANY part has ALWAYS a PartBody (which is called MainBody in VBA)
so, you need to loop thru your assembly, and for each part encountered do
part1.InWorkObject = part1.MainBody
regards,
LWolf
these lines make no sense...
Dim oPart
Set oPart = oSel 'since oSel is a Selection, and I am assuming by oPart you wanna have the part...
Set documents1 = oPart 'even here, you set documents1 to be, in fact, oSel...
Set partDocument1 = documents1 'and here...
regards,
LWolf
I took it that oSel would be the result of the search and so would be the part body.
When I run the code it does select all the part bodies in the assembly.
I'm struggling with selecting the parts / bodies and making them active.
cheers gents i'll have another go
the big part in your task is to loop thru all the parts...
usually that is achieved with a recursive loop.
as you can see, the sub ToTheJob is quite easy...
Option Explicit
Sub CATMain()
Dim ActiveModel
Set ActiveModel = CATIA.ActiveDocument
ActiveModel.Product.ApplyWorkMode DESIGN_MODE
Dim products1 'As Products
Set products1 = ActiveModel.Product.Products
Dim k As Integer
Dim FullPath As String
For k = 1 To products1.Count
FullPath = products1.item(k).ReferenceProduct.Parent.FullName
If Right(FullPath, 7) = "Product" Then
Call Sub_Product(products1.item(k))
ElseIf Right(FullPath, 4) = "Part" Then
Call DoTheJob(products1.item(k))
End If
Next
End Sub
Sub Sub_Product(ActiveModel)
Dim oProducts
Set oProducts = ActiveModel.Products
Dim oProduct
Dim k As Integer
For k = 1 To oProducts.Count
FullPath = oProducts.item(k).ReferenceProduct.Parent.FullName
Call Sub_Product(oProducts.item(k))
Call DoTheJob(oProducts.item(k))
End If
Next
End Sub
Sub DoTheJob(oProduct)
Dim myPart
Set myPart = oProduct.ReferenceProduct.Parent.Part
myPart.InWorkObject = myPart.MainBody
End Sub
regards,
LWolf
Think I get what you mean lol
I will try :)
thanks
Thanks Lwolf :)
Could I ask what the ", 7" & ", 4 does ?
cheers, that's brilliant
right is a function that takes a string, and looks up the characters from right...
pls. google for it. So basically the last 7 characters need to be "Product"
and so the other one checks that the last four characters spell out Part...
Alan, if you want to learn some, then by all means do search the internet... start your searches with "vbscript function.to.learn.about"
regards,
LWolf
Hi.
A few notes on code above:
1. "Option Explicit" is the absolute must as it eliminates errors that are VERY hard to track down. I wish it was applied by default, but Microsoft thought otherwise.
2. Better not to use file extension to validate object type. Code above requires extra tuning to work with case-sensitive file extensions (i.e. "CATPART", "catproduct")
There is a direct way to determine object type - use TypeName() function (or "is" VBA statement)
3. "Call" statement is redundant and what's worse makes code non-portable to CATScript (which is always better choice over VBA unless you need UI forms).
4. For..To is not required as well, it's slower and less convenient than For..Each
Code:
Dim prd, strType
For each prd in ActiveModel.Products
  strType = TypeName(prd.ReferenceProduct.Parent)
  If strType = "ProductDocument" then
    Sub_Product prd
  ElseIf strType = "PartDocument" then
    DoTheJob prd
  End If
Next
End Sub
Thanks guys,
Lwolf, I have googled loads regards scripting and bought the vb scripting course from Emmit Ross but I do struggle getting my head around it.
I will be spending a little more time on it next year.
While i'm here, could you help with the other thread I've posted.
Spent hours trying to get the value from the 'Length' properties box but keeps giving me the value from the 'WIDTH' box.
Is this because the designer used 'Length' instead of 'LENGTH' or some other term that isn't already a property ???
cheers guys and have a good Christmas and new year :)
Hi
Pitty is not like this in 3DEx...
Code:
Sub CATMain()
Dim productDocument1 As Document
Set productDocument1 = CATIA.ActiveDocument
Dim selection1 As Selection
Set selection1 = productDocument1.Selection
selection1.Search "CATProductSearch.Part,all"
For X = 1 To selection1.Count2
    Dim part As part
    Set part = selection1.Item2(X).Value.ReferenceProduct.Parent.part
    part.InWorkObject = part.MainBody
Next
End Sub
Fernando
