I'm not up to speed on design tables. I never had the need for them, until now.
I'm creating 6 configurations of a part that is based on a part within an assy that also has 6 config's/sketches.
The problem I have is I can't change the dimensions, I need the dim's to move to another point on the sketch, or add a new dim for each config while suppressing the previous dim.
I'm not sure if this can be accomplished with a DT.
Is there a way to make the configs using new dim's?
Attached is part of the assy (I can't show or attached the complete file). It shows one of the dim's that needs to change to the other points of the sketch.
I was able to make this work by dragging the point of the dim to the new point and selecting for this config, but it only worked until I finished the 3rd config and everything got out of wack!
SW couldn't handle that much info change in the dim.
Chris
SolidWorks 11
ctopher's home
SolidWorks Legion
Chris
SolidWorks 11
ctopher's home
SolidWorks Legion
