pedersonpoint
A metal recycling customer that has two Caterpillar 3516A mechanical engines "NOT" generators. The engines are coupled to a pulley system through air clutches that simultaneously engage putting the machines in parallel. Both engines have 2301A short board speed controls that drive EG10P actuators. The engines do not proportionally loadshare do to the misapplication of the type of speed control used.
Woodward does offer a 723 speed control that uses a 4-20 ma input from a rack position sensor or from a 4-20 ma output from a manifold air pressure transducer.
Does anyone know of a cheaper alternative then using two Woodward 723s
