pantswagen
Automotive
I am having machined some custom front hubs
basically to suit a 1975 vw van, so single row taper bearings.
now these are steel, what I am having made are in alloy
they are replicating a porsche stud pattern, the porshe hubs they are replicating are cast alloy
my concerns are, which grade material should i use
the other concern being, they are having studs pressed in as the standard ones, I wanted them in steel, but the machinist and I know its easier to do them ally.
also whilst I am on
-the max diameter on the finished item is bob on 150mm
-the machinist says he is to charge me for the next size up, as he has to true the billet, is this correct?
also whilst I am on
