M
manriquea
Guest
I am designing primarily crates (large custom crating for military etc.).
I would like to streemline my process and have a question which I would guess could be called parametric assembly.
Say for example I have a frame made of 2x4's. This would be an assembly of 4 separate parts (square frame). However I do not want to define the parameters other than square corners. This way I could alter the size of the frame (height or width) for each job without having to redraw the frame for each unique dimension each time.
Is there a way to do this? Or must I go back and change the part file each time I want to change the assembly.
