Parameters insertion inside bodies
Heli2328
IN
Is there a way I can create new parameters inside a body directly instead of them being created under the parameter category on the top of tree?
The work around is to cut and paste the parameter inside the body of work (if hybrid design for parameters is enabled). but I would like to know if there is a direct method to have a parameter created inside the selected body. Thanks.
See image for clarity
