Due to the obscene language used by one of the member some replies were removed.
It will be much better to keep the discussion here technical and polite. Our degrees, work experience, membership on standards committees, etc lend no weight to an argument. Only the technical merit of our assertions and the support we provide for them has merit. We are all learning. (Thank you Dean)
Some deleted comments were a blatant attack on members. Please refrain from personal attacks. We completely respect your knowledge and experience and sincerely appreciate your opinion and contribution to the forum, but we will not tolerate attacks on individuals.
OP question: “how much AUTOMATIC parallelism control is for both faces of a cylinder?”
Answer: If we arbitrarily select one of the side faces as a reference surface, the second face won't be out of parallel by more than 0.4. (Thank you pmarc)
Comments:
Can you add a parallelism tolerance bigger than 0.4? Yes you can, but will add no value and will show lack of GD and T literacy. (Y14.5 standard implied, size tolerance and rule#1)
Any questions / comments are welcome.
