I am looking for guidelines for the maximum current that a disconnect switch can break when the parallel path has a near-zero impedance (such as in the same station). The voltages I am looking at are 46kV through 161kV.
Specifically I am wanting to open the bypass switch for a breaker after putting it back in service without opening the breaker and dropping load.
I know that the voltage across the switch before and after opening is practically zero. But the current, obviously, is not. Is it possible for the voltage to be low enough that current does not matter?
Thanks in advance.
Thanks in advance.
