Hello
Looking at a pumping system comprising 3 VSD centrif pumps discharging into a rising main. Pumps can run either on their own or any 2 in parallel. I want to ensure that in parallel the load is shared and pumps run at same speed. To maintain a dedicated pressure in the main, is it best to just use pressure set-point to increase / decrease pump speed (or pump run current) or would control be better if flow set point was also used ie if actual pressure higher than set point, reduce flow set point and reduce pump speed to match? Control will be via PLC so PID loops etc can be programmed in to suit.
Cheers
Jo
Cheers
Jo
