jimandrews
I have what is surely a simple question for you structural guys, but I am but a mechanical engineer! If I have 2 equal beams in parallel that are interconnected by "rigid" struts periodically spaced down the length of each beam, and I apply a distributed load to one of the beams, how do I calculate the effective resistance to bending for the assembly? Assume that the reaction to ground occurs at the ends of the non-loaded beam.
Perhaps more to the point -- do I use the parallel axis theorem to calculate an equivalent (larger) moment of inertia? It seems that this could produce a VERY stiff result, and one that I doubt. Is the parallel axis theorem applicable to beam assemblies, or is it merely suited to calculating the moment of inertia for a monolithic single beam of arbitrary shape?
Thanks for any help.
jim
jim
