It would not surprise me because you could easily fold it into a binder and many copiers will handle it.
I prefer D size but my field is machine design. It has enough room for most components without crowding views and dimensions and you can fold it into an A size. I can't stand E size and will use multiple sheets of D before I make one single E drawing. They are too hard to fold and you can't lay them down on a desk (at least on mine), not to mention plotting them.
I agree with Chris. D is a good size. You can fit much detail on it and it is still readable when printed to a B size. Any larger format, and you loose too much when printing to B.
I've always like A1 and A2 sizes for metric and thier closest ANSI relatives, the C and D size. They're just much easier to handle, fold, and lay on other people's desks. If I'm going to be explainging a print to several people in a board room I'll print out the A0, but otherwise it's gotta be a managable A1.
I like to hang E sized drawings on the wall. It is an ideal size for arrangements, where you want maximum size and detail.
I have a strong preference for 1:1 scale on fabrication drawings. In many cases, you can do a quick and dirty inspection by lying the part on the drawing. This results in a lot of E and D_sized drawings. If you use 4mm or 5/32" fonts, the full sized drawings are readable from a distance (when they are hanging on somebody's wall), and the reduced sized prints are readable.
Our assembly people do not want to see anything larger than D_size. Big drawings do not fit on work benches.
I'm with Chris on this D-size then print 1/2 scale 11x17. Although, I have done multi sheet E size drawings for some pump housing castings and machine drawings.
Our assembly dept. barks at anything over a B-size.
It would be a wonderful thing if we could really go paperless....wasn't that the initial selling point of CAD?
Best Regards,
Heckler
Sr. Mechanical Engineer
SW2005 SP 4.0 & Pro/E 2001
Dell Precision 370
P4 3.6 GHz, 1GB RAM
XP Pro SP2.0
NIVIDA Quadro FX 1400
o
_`\(,_
(_)/ (_)
"There is no trouble so great or grave that cannot be much diminished by a nice cup of tea" Bernard-Paul Heroux
Heckler, I agree.
Our company announced 2 years ago we were going paperless. Everthing went on-line, automated, etc. Now we generate more paperwork than ever!
Chris
Sr. Mechanical Designer, CAD
SolidWorks 05 SP3.1 / PDMWorks 05 ctopher's home site (updated 06-21-05)
FAQ559-1100
FAQ559-716
D-Size seems to be the way to go. We are quite some distance away from our mfr, so every drawing is made a D-Size PDF. We print a hard copy on 11X17 here in the office, and they can print whatever size works best for them there. PDF actually is great. I think we may even go from hard copy to PDF only if we can figure it out... then only print something out if necessary... which now that i think about is is all the time.. but what the hell... many wrong paths where departed walked with good intentions...
We still use both Autocad and Solidworks. Some people have viewers and others don't, some don't have plotters, some even want R14 drawings. I am starting to put everything on pdf and email it to purchasing so they can do what they want with it. I quit plotting drawings and putting them in the mail.
I may have plotted two drawings in the last three years. Everything is in cgm format and printed on B size paper. We may not be paperless, but we do use less than we used to.
It stands for Computer Graphics Metafile, and is used somewhat like a jpeg. This is the drawing file that everyone gets to see here, as well as the format we send to our customers.
