I am trying to find a valid approach for the following problem:
I would like to use a Pall rings pack in a counter-flow heat exchanger. Flue gas from natural gas (CH4) combustion, should rise from the bottom of a column, while sprayed water should move in the opposite sense. Pall rings should contribute to fraction water droplets and increase the surface involved in the heat exchange process.
Water flow rate: 6.6 m3/hr
Temperature rise (deltaT) required: 60 °C (Tin = 5°C; Tout = 65 °C)
Flue gas flow rate: 735 m3/hr (49 m3/hr of CH4 for combustion process and 15 m3 of flue gas per each m3 of CH4).
Power required = 470 kW I have considered a high efficiency for this process (98%, maybe even more). Column (H = 2.5 m) is well insulated and sensible heat loss from stack should be very low (very low flue gas temperature from the stack after the Pall ring pack).
Pall ring specs: as per table attached.
And now my questions:
1) Can in your opinion this heat exchanger work properly?
2) Can anyone help with formulas to size the column width and the height of the Pall ring pack to meet the requirements indicated above?
Any comments very appreciated
