palete of colors?
pascual
75
Does anyone knows how to define a palete of colors to use in every new assembly?.
The problem is that I have to present designs and for easy visualisation I aply a lot of colors, but I have to define them in every assembly. The solution'd be to have some colors predefined
If you check out and become a member you can download a colour palete file to go in your config file, it has 40 colours. Of course you can only change the colour of a part in part mode. I created a mapkey button that brings up the palete straight away, I find it real useful.
Once you've got a color.map file (either downloaded or created) - save it into your working directory - then Pro/E will use these colours by default.
Ed
Err.... sorry it is fawcett with two t's
