Hello everyone,i hope i am not doing anything against rules asking for a help here.Friend of mine have some loader that plans to equip with forestry mulcher,hydraulics is not my profession and it would mean allot if someone can help me out with this.
So uhm,i guess i need to start with numbers ,loader is not large one ,but there is smaller ones,he is 15 ton weight,have 3 hydraulics pumps,but important one is main pump ,which is gear type ,260 liter per minute max flow ,at 140-160 bar pressure,210 liter oil reservoir ,but have no oil coolant.What he is planning to do ,is buy some used tractor pto powered forestry mulcher ,add hydraulic motor to it and connect it with loader.Question is,in order to know what size of mulcher to buy ,he need to knows what size of hydraulic motor he can use for that pump.I did some research on net ofc,there is several types of motors,like gear ones ,piston radial,piston axial ....apparently motor with highest torque is piston radial type ,but still he is not sure how to pair them up.Since motor would be connected on mulcher pto connection,it should spin +- 500rpm.Forgot to mention,at the front of the loader,where bucket is ,there is 2 quick connections for hydraulic ,it can operate 1 double acting cylinder.
Some piston radil motor he found for sale ,he knows it's 150cm3,max rpm 500.
Loader hydraulic gear pump is 133cm3 if i remember,it's this type from this bellow pdf file >3115.407.74M
