Hi all, can anyone shed some light??
I've got a steel cylinder to the sides of which I'm welding 2 diametrically opposing padeyes. The padeyes are attached to steel ropes which are applying a load logitudinally to the cylinder, in other words the load is trying to shear the padeyes from the cylider wall.. The shear stress calcs are fine but my problem lies with the moment caused by the load acting at the pin at a distance from the cylinder wall. This is the force which will act to buckle the cylinder as a load is applied.
I started thinking I could treat a longitudinal strip of the cylinder wall as a flat beam, with the padeye producing a push/pull type force system trying to bend the beam. I could then use standard beam bending theory to calculate the bending stress in the strip. However I've found this to be a far too conservative as the curvature of the cylinder has too great a bearing on the second moment of area.
Short of an FEA analysis, does anyone have any tips on how to approach this problem.
