Packed Joints Query
SnTMan
(Time to "forum shop" this one)
Hi all
Anybody know of a rational way to pressure-rate a packed joint?
This would be a type of joint using something like a stuffing box, rope packing and packing gland.
They are fairly common in S&T heat exchangers in the form of test rings, used for leak testing a shell/bundle at ambient temps with a shell cover removed.
Some customers seem suprised that we do not advise using them in 60" dia. at 700 psi, so a rational rating method would be very helpful.
Any ideas? Thanks in advance.
For what it is worth, a detailed study of the design and performance of packed joints was made by Stone and Webster about 15-years ago. I don't have a copy, as I recall they wanted $500 for the report. Maybe you can locate a copy through R.I.C.E. at Rice University's Fondren library.
Good luck,
DowneastTech
DowneastTech
Mechanical Engineer
Magnus R & D, Cypress, TX
DowneastTech,
A web search didn't turn up anything on this, unless it is part of some other paper.
Thanks anyway, may try my public lib.
The only other source I know of for a rational approach to packing is given for the design of packing glands for valve stems and can be found in " The Valve Designer's Handbook" by Jerry Lyons. Probably Abebooks on the internet will have a copy.
DowneastTech
Mechanical Engineer
