Hi Everyone,
Thanks in advance for your valuable time and feedback.
A bit of background: I am a junior engineer, fresh out of college, and have been given the opportunity to design a unistrut frame that will carry a ceiling mounted cauterization lab machine weighing 2-tons for a hospital (ref to Image 1 below for 3d concept of cath lab - yellow highlight).
Image 1 - 3D Concept of Cath Lab (Yellow Highlight)
That cath lab consists of a C-arm and 56 inch monitor that are movable and are attached to a rail system. According to the suppliers specs, I am supposed to specifically use a P1001 unistrut system(configuration is my choice) to connect the rail system of that Cath lab to the ceiling of the hospital wing set apart for this equipment. The image below shows the specific room of the hospital wing the machine is to be installed in.
Image 2 - Existing Site Picture
After my site visit late last year, I saw that the hospital wing in question was a single storey structure of concrete/masonry construction with a timber framed and corrugated profile tin/metal sheeting clad roof - essentially, the existing ceiling is incapable of carrying 2-tons of weight and that a separate steel frame would need to carry both the unistruts and the cath lab machine.
Unistruts are something that I have come across for the first time so I'm jumping off the deep end with this. My on-going research seems to suggest that I can configure them as trusses but complying with some of the manufacturers requirements - especially with the stiffness requirements, really befuddle me.
Here are some of the requirements for context:
Image 3 - Specs 1
Image 4 - Specs 2
Image 5 - Specs 3
Additionally, because the cath lab unit is one that has moveable members, the supplier also provided static and dynamic forces for the design (ref below). I'm still in the process of clarifying with them about the distribution of the forces.
Image 6 - Static Forces
Image 7 - Dynamic Forces
I tried to be as detailed as possible with this item of mine and I'd appreciate your advice on how I'd go about using them for this medical application.
Cheers!
Image 3 - Specs 1
Image 4 - Specs 2
Image 5 - Specs 3
Cheers!
