Pressure units non consistent (mix of bar and psi, SI with gallons etc)
Compressor discharge pressure apparently confused with MAWP
bar and barg again mixed up. "bar" is absolute... seems very sloppy.
Why killing pressure from 6.6 to 1.2 barg, that's a lot?
Potential risks?
What type of compressor is this ? recips or diaphragm type ? I expect many stage with intercoolers going from 1.2 to 243 bar. This is not shown?
Why PSV only on the suction pot ?
I don't see pulsation bottles unless you use the knock out pot for same purpose, what about discharge?
Flange in and flange out of compressor cylinder should have same pressure rating I'd expect.
My two cents
