Lesali
- Jul 10, 2008
- 21
I've designed an OCBF equipment platform in the Tahoe area where the snow load is 230 psf. While the "X" bracing utilizing L3x3's works well for the lateral design (as tension only or Euler buckling members), if I consider the compression they would "see" in the D+S case they are overstressed by 80%. I had an idea that by using short slotted holes (and slip critical connections) in one end of the braces, the dead load stress component could be removed after the platform is loaded by releasing the bolts and retightening them. Then, only the snow load induces compression in one brace at 100.2% d/c (for the max design snow condition and I can accept that).
Does this seem a reasonable approach?
Is there a safety concern that should be addressed when the braces are released and tightened after the dead load is applied?
Should the structure be analyzed for the increased drift and P-d effect under a seismic event if the bolts slip to the end of the slotted hole?
