bones206
- Jun 22, 2007
- 2,000
There is a bit of debate in my office and I am currently in the minority. My boss and others think that we should design the anchor bolts for a 90 ft tall process vessel (SDC C) using the overstrength factor option of ACI 318 Appendix D/Ch17. My understanding is that the overstrength method of designing anchors for this specific situation is prohibited by ASCE 7-10, Section 15.7.5:
15.7.5 Anchorage
Tanks and vessels at grade are permitted to be designed without anchorage where they meet the requirements for unanchored tanks in reference documents. Tanks and vessels supported above grade on structural towers or building structures shall be anchored to the supporting structure. The following special detailing requirements shall apply to steel tank and vessel anchor bolts in SDC C, D, E, and F. Anchorage shall be in accordance with Section 15.4.9, whereby the anchor embedment into the concrete shall be designed to develop the steel strength of the anchor in tension. The steel strength of the anchor in tension shall be determined in accordance with ACI 318, Appendix D, Eq. D-3. The anchor shall have a minimum gauge length of eight diameters. Post-installed anchors are permitted to be used in accordance with Section 15.4.9.3 provided the anchor embedment into the concrete is designed to develop the steel strength of the anchor in tension. [highlight #FCE94F]In either case, the load combinations with overstrength of Section 12.4.3 are not to be used to size the anchor bolts for tanks and horizontal and vertical vessels.[/highlight]
The underlying philosophy as I understand it is to force the anchors to be the ductile "fuse" of the foundation/anchorage system in order to promote bolt yielding, which absorbs the seismic energy hysterically and helps avoid a brittle-type failure or foundation overturning. I've read the ASCE
Does anyone know if there is an alternative approach where the overstrength factor method can be utilized, that is also code compliant? In other words, am I wrong or is my boss wrong? Either way I lose![[thumbsup2] [thumbsup2] [thumbsup2]](/data/assets/smilies/thumbsup2.gif)
15.7.5 Anchorage
