FlyingTrike
I am trying to work out a problem with a direct drive setup on a motorcycle trike. It has a solid 2" axle that is very wide for a trike. I tried it with both wheels locked to the shaft and I could not takeoff from a stop and turn. It goes straight.
Then I made the right wheel turn free on the shaft and it turns, and easier to the right of course. The problem with that is that it now will not drive straight under any accelleration. It pushes hard to the right.
I believe that what I need is some sort of overrun clutch hub, maybe a bidirectional one, for each wheel, but I am not sure. Freeing one wheel makes it turn better, but it is still harder to turn left with the right free, so that is why I think that it needs two clutched hubs.
Maybe there is a way to adapt a mechanical clutch to each wheel, or maybe an electric clutch that can be operated by a switch to disengage each side as needed? Maybe a bidirectional overrun clutch?
Any suggestions will very much be appreciated.
Thank you!
Steve Thomas
Thank you!
Steve Thomas
