Skogsgurra
I visited a mobile container crane the other week. DC motors and thyristor controllers fed from a diesel generator. Customer complains about repeated undervoltage tripping.
I immediatley felt an acrid smell around the crane. Smell came from cooling air exhaust for hoisting motor. Found out that current was around 1200 A when lifting 30 ft containers. Motor rated current is 636 A. Motor had been replaced. Was stronger and needed less current before.
Customer worried. Me too. Crane manufacturer had a motor with 750 A and 4.3 Nm/A installed before. New motor has 3.3 Nm/A. So, original motor needed less amps to lift the container and new motor (with lower rated current) needs more current.
Case closed as far as I could see. Repair original motor and put it back in service is what I recommended the customer. That will also take care of the undervoltage tripping caused by generator overload and deep/broad commutation notches.
But I had not taken the crane manufacturer into account. He now says that he knew about the overload all the time and that the new motor (somehow?) was designed to take the abuse.
I have some difficulties accepting this. What are your opinions?
To recap: Acrid smell around motor, close to twice rated motor current, undervoltage trips. What do you think?
Gunnar Englund
Gunnar Englund
