Overiding Rule #1 3
SpaciouS
Why was the ability to override Rule #1, with straighness on a FOS dimension, created in the first place?
I'm curious to hear other people's opinions.
Thanks,
Sean
Basically, in practice, for too many cases "the envelope principle" is unrealistic.
Frank
Since Rule #1 is a catch-all default that controls form unless otherwise specified, then having a straightness tolerance on a feature of size counts as "otherwise specified."
John-Paul Belanger
Geometric Learning Systems
As I understand it, the only time rule #1 is overridden is by the following:
1) Special note stating such override
2) Stock material is not applicable
3) Straightness control on a FOS dimension
So in terms of geometric characters, there is only the one way. That's why it's curious to me. But after thinking more on it, I tend agree with fsincox and his comment about an unrealistic envelope. In a lot, if not most cases, straightness control of a FOS (axis or median plane) would be for long parts. By virtue of the indirect form control of Rule #1, the envelope for a part that is long can be unrealistic if the size tolerance is relatively small.
I think this logic makes sense.
Thanks,
Sean
If you followed my link, you would find 4) When LMS/LMB is applied.
To Sean's list, another would be non-rigid parts: Rule #1 doesn't apply for non-rigid parts subject to free-state variation.
John-Paul Belanger
Yes that's right, non-rigid parts subject to free-state, as shown in CheckerHater's link, is another case...
I was really focusing on geometric characters, more than anything, and the fact that there is only one that applies and even that has to be specifically relative to a FOS dimension. Just a nice mental note, that no other geometric characters override Rule #1.
Thanks,
Sean
True as long as you are working to '94 version of Y14.5. In Y14.5-2009 there are two additional ways to override rule #1:
1) Independency modifier (I in a circle) - which is nice and short substitute of text note.
2) Flatness control on a FOS dimension - controlling derived median plane of a non-cylindrical FOS.
Rule #1 does not apply to an irregular FOS, it only apply to regular FOS.
Season
Ahh okay, thanks for the tip pmarc, I was not aware of this.
I will review the 2009 standard on this topic!
Thanks,
Sean
