EITengineering
Hi Everybody,
I have a simple question regarding 50/51 overcurrent relays.
I understand that these relays have both a tap range and a tap setting within that range. Some of these ranges however overlap, i.e. Tap range 1.5-6.0 & 4.0-16. My question is if I have a tap setting of 5, does it matter which Tap range I choose? Are the characteristics of either range different given that my tap setting is 5 for both?
I searched the forums and I read one posting that the range is related to short circuit current. Is this range supposed to be a max withstand rating of the relay?
Thank you in advance for your help!
