Over voltage relay
train1
I am looking for a over voltage relay with a trip setting at ~1200 vac. Where can I find it. Also I will need high voltage connectors.
just on the net and around our office.
no where of any use.
You won't get much help here is you keep acting like this! If you want some help, you might want to answer some questions! Your smug attitude is probably what's causing your problems. I would be willing to bet, that if you looked in the right spots on the net, you could find your answer. However, you have decided to be a lazy, smart alec, and waste time of true professionals who would have been willing to teach you how to solve your own problems. Good luck in finding your device.
Most OV relays at this level use transformers to step down the voltage to something more manageable, like 120 or 240. Then they monitor this secondary voltage. I am sure there are devices that monitor the 1200 direct but am certain they will cost quite a bit more.
