Hi all,
I apologize in advance if this is not the correct thread category. I have an application for a coolant manifold (50/50 ethylene glycol/DI water) that will experience max temp of around 70C and max pressure around 14psi and am in need to create this out of a thermoplastic material. To do this successfully, I also need to incorporate two locations for an NPT thread pressure and temperature sensor (1/4" NPT and 1/8" NPT respectively). I believe I am limited to these sensors at this time, but was wondering if there was much experience with overmolded NPT inserts. They do not seem to be readily available in that thread style in the market, so I am guessing it's not very common. I would assume there are issues with overtorque/leaking, but do not think that will be that big of a problem since this is low volume and we have skilled techs building our assemblies. Any experience on using an overmolded NPT insert and where can I find them? The thermoplastic material will be PVDF.
