atmengr
- Sep 2, 2005
- 14
Hi All,
We have some underground piping that has been out of service for 4-15 years depending on who I talk to. The line has not been under pressure, and we are assuming it was not decontaminated (product was ~clean butylenes). We want to put the pipe back into its original service.
I am interested in what kinds of NDE, inspection or testing others would require, if any, as well as other considerations that should be made. For some information, the system is 150 lb system, std pipe, cp readings are good, a buried check valve is in the system, and it will operate at a max pressure around 70 psig.
I would appreciate any thoughts around this, thanks in advance.
