REDesigner09
Aerospace
I have a turbine blade and the airfoil concave surfaces or face has a very noticeable questionable vertical surfaces or faces in the middle of it. This is most noticeable when Shading with Edges is on & of course, when shading without edges is off, this area looks perfect.
My question is that is CAD model is considered a "validated" model, which will be handed over to ANSYS operators & I think CNC operators. If they inspect or analyze this model, will they also see these questionable surfaces or faces?
More importantly, how are these questionable surfaces / faces affect end ANSYS analysis & CNC programming or any other CAD model analysis?
If this is an issue & not just an appearance issues then I need to justify the "risks" or "ramifications" to the Design Engineer & Management that not fixing this area will cause ....???
