Osnap markers
en20248
In ACAD 2002 I make osnap=4 (center), but when I draw line to another line I see an endpoint , midpoint, intersection and other markers.
I don't like it.
I want to see only center marker like I had in ACAD R14.
How can I fix it?
Your SV OSMODE = 4 and You see the osnapmarkers??? Sure? I never heard this.
BTW, how do You draw without osnaps?
Lothar
ADT 2004
ACAD 2002
When I Clear All in osnap I see markers.
En20248
At the bottom of the screen there should be a osnap button. Right click >> Settings. You'll be able to set your osnap modes there.
____________________
Acad2005, Terramodel
I know how to set Osnap setting. I cannot remove unwanted markers.
Have you exited Acad/rebooted lately?
I shut down Acad every day.
I wanted to make sure. Do you see OSNAP highlights or are you seeing Grips?
"Everybody is ignorant, only on different subjects." — Will Rogers
I see markers like circle, triangle, x, perp. sign etc.
You have other osnaps turned on. Do as lpseifert says, and right click on the osnap toggle at the bottom of the screen and select settings. You will then be in the object snap tab of the drafting settings dialog box. Here you can check and uncheck which osnaps you would like to see on or off.
Sorry, but it does not work.
I would try to install the service pack.
And update the driver for the videocard.
How long does the problem exist? After the installation?
Lothar
ADT 2004
ACAD 2002
Yes, after the installation. Sometimes it works properly, but mostly not wright.
