Oscilloscope Connections.
jethro99
Student
Got a new oscilloscope to play with. 126 page user manual but with no advice as to how to properly connect the test probes.
Would someone take a look at the illustrations below and let me know if I am thinking correctly? It would be appreciated.
online photo hosting
Oscilloscope ground should NEVER be connected to anything except a ground. I nearly got got hit by a chunk of an exploding IC when I connected an oscilloscope ground to chassis, which I naively assumed was ground; it was not and it was actually hot.
TTFN (ta ta for now)
Agree with IRStuff. A safer approach to taking the measurement you want in your second example would be to take a ground from the vehicle, then use two separate probes on the stator outputs and set the scope to display the difference between the two channels.
A.
An oscilloscope with two inputs will typically have a Ch2-Ch1 function to get differential measurements without compromising the ground.
