orifice plates
josemiguel
VE
do you know a method for calibration of orifice plates?
What do you mean by calibration of orifice plates? Do you mean verification of their flow measurement similar to calibration/proving that is done on turbine meters?
Orifice metering of flowing fluids is one of the most thoroughly documented subjects. ASME has published some superb texts, and numerous other sources are readily available. If your orifice dimensions and adjacent piping configuration are known with sufficient accuracy, the flow characteristics of your system can be determined with reasonably predictable accuracy.
Josemiguel:
Orifice plate measurement is fully documented for inspection and manufacturing calibration in AGA Report Number 3 (API 14.3).
It is worthwhile reading and would strongly recommend it.
Kenneth J Hueston, PEng
Principal
Sturni-Hueston Engineering Inc
Edmonton, Alberta Canada
I am sourcing for a Positive Displacement Piston Prover for calibration of Turbine Flowmeters mainly use in Aerospace industries. Could anyone advice me on which are the more reliable Manufacturer. Thank You.
Open a new tread - that would make more sense - besides try your flow meter manufactor they might know?
Best regards
Morten
Go to This is an excellent article on meter calibration and meter proving. It should help you evaluate suppliers a little better.
JMW
Eng-Tips: Pro bono publico, by engineers, for engineers.
