pipe15
- Jul 22, 2005
- 69
ok, I see that std orifice flange tap is 1/2 npt, which is easily changed to socket if desired. what if you want 3/4 socket? I see that on many P&ID's, but it looks like it will violate min weld size near the flange facing edge. how do you get around this requirement for weld size?
last, what are the downsides, if any, to just using a male by tubing adapter and coming off the orifice flange with the instrument tubing, eliminating all hard pipe off the orifice flange?
thanks in advance,
mark
thanks in advance,
mark
