Depends on characteristics of muck - just mud? or amorphous/fibrous peat. Besides some of the above, careful installation of wick drains, surcharge loading and the like can be done. Also, can consider to use the rolling surcharge method (this is described in Tshebotarioff 1951 - from Michigan DOT of 1947). I used it and successfully displaced some 40 ft of slimy tailings in South America. If needbe, can also use explosives to remould the material even further and then use displacement methods as I noted above.
GeoPaveTraffic's comment, though, is not one to dismiss. One needs to be aware of the complexity and careful attention needed in applying all other than, say piles (although there would be other non-pile issues), to a project built on "loon shiesse". Sometimes, it is best to walk away from a project that might not get you enough revenue to make the risk acceptable. Risk analysis is not always about the project foundation type, etc. It is as applicable to the firms involved. Also, it might be best to advise the client (potential) client about the risks - and by all means if you go ahead, keep the client forewarned about the risks, etc. (keep it in writing, etc.)
