Ordinate dimension offset
tap90291
106
Is there any way to change the default value for the first ordinate dimension from zero to some value that will carry through the rest of the dimesions. I need to insert a datum elevation other than zero on some equipment and then show the subsequent elevations without having to go in and edit the dim text.
TAP
Is this on a drawing? In a drawing, you can just drag the 0 ordinates to new locations and all the referenced dimensions based from that 0 will update. You will get a message asking you if this change is intended.
Why not just create a point or construction line (datum) where the real zero elevation would be. It can be outside of the drawing border if necessary.
[cheers] & all the best.
In Option\Document Properties\Detailing you can set the offset.
crjones ... In what version of SW? I don't see that in SW04.
